In preparing to change the cutlass bearing on 1996 C30, we discovered the set scews on the prop strut would not hold the size 3.5 Allen wrench which just spins. It begins to bite and then just pops off. Size 3 is too small and size 4 won't fit. It appears the hole has been stripped unless there are different type of Allen wrenches like metric and standard?
Will drilling the set screws out with an Easy Out tool work?
Thanks,
Tim
Thanks,
Tim
