Cutlass Bearing replacement
222
Hunter H340 Michigan City
Well it has come time to replace the cutlass bearing on my 84 H31. I will probably do it in the three weeks weather permitting. So does anyone have any advise, sage wisdom, smart a..s comments? It is the first time I am doing it so any thoughts would be good.
Thanks
Keith:eek:
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
FYI you can also do this job without removing the shaft, which can be a big PITA. If you can get your hands on a cutlass bearing remover/installer you will only need to remove the prop and will save a lot of work.
garyc
Oct 4, 2008
63
Hunter 27-76-84 mallets bay,vt
I agree with Allan. Some people have made their own extractors from pipe and threaded bolts. I was lucky and was able to borrow a cutlass bearing puller. Whole job took less than an hour
Feb 22, 2004
222
Alan
Where can i get that tool to remove the bearing without removing the shaft?
Thanks Keith
Oct 17, 2008
25
nunter 31 george town m.d.
Keith Sorry it took so long to get back to you.I asked the same question on 1-8-10.HunterDon 31 made a tool to do the job without removing the shaft. It is now on page 5 of this forum. I hope this helps. Max s
Feb 22, 2004
222
The right tool fro the job
Yes I bought the STRUT PRO it worked great. I am going to write a short piece with photos when I get a few minutes. But let me say this it took less than an hour and there was no removing parts, shafts, or seals. No beating with hammers. It was smooth as silk. Just wait till you see the photos and read how darn easy it is.
Keith :dance:
