1978 hunter 27 w/ yanmar sb8. I think I need to replace my cutlass bearing. Is it possible to remove the prop and then unscrew the cutlass from the bottom of the boat...then slide it off the shaft? This would allow me to remove the old bearing and install the new off the boat. Is there enough slight bendable motion in the shaft to slide the cutlass off without removing the rudder?
