Cutlass Bearing/Plastic Bushing
May 11, 2015
27
Beneteau 323 Sakonnet, RI
Anyone know the life span of the plastic bushing in the cutlass bearing?
How about the part #
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Literature search suggests these bearings can have a 10 year life expectancy but this will vary with use, shaft alignment and local conditions. A correctly sized bearing on an unworn shaft will exhibit very little movement, if any. Excess movement will cause problems, just as any worn bearing will with rotating parts.
See posts #3-5 in this thread for the part number: Cutlass bearing specs
Also you can check this site for a cutless bearing: SailboatOwners.com search
7,381
Mine is 22 years old from the factory and the shaft shows no radial deflection. Mind you, I'm a nut for shaft alignment.
Curious as to your mention of "the plastic bushing". Unless you've got an oddball, the internal sleeve is grooved rubber.
What makes you think you need a new one ?
