Cushions release frozen zipper to remove cover for cleaning
14
2 25 Barnegate Nj
THE CUSHIONS ON OUR ODAY 79 25 FT, ARE LIKE NEW ORIGINAL CLOTH, HOWEVER THE ZIPPERS ARE FROZEN, ANY SUGGESTIONS, TRIED VINEGAR AND WD 40
Paul Finch
Frozen zippers
I had the same problem when I bought a small Hunter and began the clean up and restoration process. I tried everything like I'm sure you've done. I ended up replacing the zippers along with all my foam padding in the cushions. All is well now. Good luck. Paul
Dec 2, 2003
480
Catalina C-320 Washington, NC
water
We had the same problem on a previous boat. Salt carried in the moisture in the air had condensed out leaving a deposit on the plastic zippers that locked them up due to friction. I used a pressure washer on low setting to wash the salt out of the zippers and once I got them started moving they worked free pretty easily.
Tim R.
May 27, 2004
3,626
Water Pik
Try a Water Pik teeth cleaner.
Bob tigar
freeing up a frozen zipper
Try applying vinegar with a cotton ball. Leave the satuated cotton ball on the zipper head overnite. Bob
