$0.02
Plexiglass does bend. SO does Lexan.The thickness makes a big difference.I stopped at a company here in Cleveland that makes stuff out of plexiglass...charis, tables, signs...and much more. So I picked the guy behind the ocunters brain.How do you bend it without distortion? Ans: We make a male and female die/mold (a die being wood in the final shape you want).Both sides of the die are covered in felt (the secret!!!)Then, we heat up the plexiglass in our ovens.Then we lay it on the die/mold and press them together.When it comes out there is little distortion. Then we trim it to size.My experiments.I called Richie and asked for a compass cover. They didn't have any in stock and didn't know where to buy one (I should have used a surveillance camera cover). So I started to experiment. I made a vacuum box and heated the plex, dropped it on hot, vacuumed it and ta-da---one crappy cover. One quarter of the dome didn't come out right...you could barley see through it. The rest was clear with little distortion. It worked, till I found a compass on Ebay. Anyway, I took a flat sheet of Plex and a heat gun. I draped about an inceh of the Plex over the side of a table while heating the width of it using an aluminum floor wet-dry vacuum to spread the heat. As the Plex bent, I pushed more off the end and kept bending. Then, I lifted one side of Plex from teh table and got a really nice curve, just like a boat windshield.The problem- The Plex was only a 12" x 12" piece.I plant to try something else this summer for a Hard Dodger.
