I raised my mast in the driveway yesterday for the first time. I just lifted it my self and was surprised how easy it was. ( I am used to raising ladders though.)
Before I raised it I measured the length of the wire to the spreaders from the top down I noticed they were different by 1 1/2" and 4" too long! The manual I have says 11' so I set them at that. When I got the boat I knew the mast was bent to some degree. It looks as if it had been laying on its side on the boat with a tarp over it and maybe snow held it down about the middle. (That's a guess. The PO doesn't know what happened either. He got it that way and it sails fine... I know that if you lay it bent side down it will almost touch the cabin.)
So when I got it up it pointed at the neighbors house and I thought that wasn't right so I started adjusting the shrouds or stays?
In the first picture of my mast in the air. I have labeled it. The picture is from starboard and the other side is exactly opposite. So whats loose on the starboard side is tight on the port side.
The 2nd picture is he shape of the mast before I tightened the tight shrouds mentioned above. The more I tighten the more it straitens....
IMOH. The mast looks like it is raked hard to the back. The for stay is tight but could be tightened another 1-2". The aft stay is loose.
Any suggestions?
Any suggestions?
