Crunchy spot on deck
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
Any experience with drilling and filling with epoxy in the specific area that the shrouds pass through the deck ? I have worked on this area and found a metal plate running below the fiberglass. Because of the plate I was not able to come up with the same quieting results after drilling and filling with epoxy. Thanks, 1983 H-30...
john t.
deck fix
take your circular saw, set it to a depth of 1/2 in. saw the area that you think the plate is in. take out the plate, and any plywood that is rotten. when dry, recut some a-b fir exterior plywood to fit, coat w/ system three epoxy, then make some epox paste. dab all liberally. glue top skin back on. make a generous bevel at the cut seam
Rick
Oct 5, 2004
1,098
Deck Fix
Thanks John T, I began to think no-one was going to respond. Went to the boat this last weekend and walked the deck with out the slightest crunch sound. Perhaps the epoxy had not setup when I thought the problem was still present. By the way, when I drilled the wood -chips were clean and dry. I did hit an area around the shrouds that a metal plate had been sandwiched , wondered if anyone had any insight. Thanks, Rick..
