Engine RPM, Prop, and Transmission
All three go into what speed you'll achieve. The engine & transmission ratio determine the proper pitch required for your prop, whether 2- or 3-bladed (and, the pitch will be different for 2- or 3-blades for a given engine/transmission ratio combo).Generally, you'll want the prop pitched to achieve hull speed at the engine's recommended cruise RPM in moderate sea conditions & with a clean hull. That allows some so extra RPM to help out in more difficult sea/wind conditions or sea growth on the hull.At idle RPM, you get what you get.Variations noted between boats seem interesting. I'm wondering what a comparison of engine model, transmissions & ratio, and the prop dimensions (diameter, pitch, blade count, type- fixed/folding/feathering) would reveal.--RonD
