I have seen information regarding the cruising RPM for the Universal M25XP. As an owner of an O35, I thought it would be interesting to see what others have experienced in this regard, not only the cruising RPM but also the speed which results. Our cruising rpm is about 2200, which give us about 5 knots, maybe a fraction more. The RPM seems to be on the low side - however, the tach was checked for accuracy during the survey in 2001. The Universal specs for this engine show a normal range of 2100 - 2600, with a max of 3200, but it seems that for a boat this size, the cruising speed is on the low side. The prop is a 2-blade fixed, and has markings that show "16RH9" which I believe indicates that it is a 16 inch diameter right hand prop with a 9 inch pitch.Anyone else have similar or different numbers for these models of O'Day?Ed
