Jon
Please comment on the following specs which I am developing for a new mainsail for cruising the Caribbean. Note that the boat has new aluminum spars that are about 1 1/2 feet taller (boom is raised) than the original wood spars. ThanksSpecs:Reinforce for double single line reefing at two lower sets of reefing pointsConsider a third row of reefingreefs included with tie points(2) full battens at top and partial battens at bottomHeavy duty leech line (leach cord adjustment at the third reef position)Leech line with cleat position at each reef point Leech line with exit at reef clewSlides with nylon webbing to grommetsTriple stitching of all seamsTraditional cross cut8+ ounce Dacron material(?Ring or Headboard?)Clew cover patch extended to include 1st reef Rutgerson pressed and webbing reinforced ringsHeavy duty bolt rope with leather reinforced slider stations, pressed ring top stationLuff and foot ropes Stainless steel ring in head and tack - fitting is stainless ring webbed to sailStainless steel corner rings with load reinforcement webbingClew and reef cringles are Rutgerson pressed Super Rings.2ply leech
