T J Furstenau
Dave -I truly respect your knowledge of these boats, and your willingness to share that knowledge and offer assistance to us. To that end, I have a question that I hope you know the answer to.A little history, I have a 1994 H26. A few years back, as a result of a failed fitting in the drum of my furler, the mast came down and snapped at the spreaders when it hit the support post usually used for trailering. Fortunately, I hadn't removed it at launch, otherwise the mast probably would have gone through the bimini and stern rail. I honestly don't recall the brand of spar that was originally on it, but when my local Hunter dealer replaced it, what was used was a US Spar (Zspar). It was different enough the the mast foot was not QUITE the same as the old one, and it never fit to my satisfaction. The dealer made some aluminum shims to fit between the foot and the base, but it was always a hassle when stepping/unstepping the mast. I found the proper base on the US Spars website and ordered it. I went to exchange the bases, which brings me to my problem.I can't get the old base off! It is a stainless base, which appears to be fastened to the compression post. My question is, did they weld those bases to the top of the compression posts? I've removed the four bolts holding it in place, and it won't budge. Even gave the base a few SOLID whacks with my sledge, but it doesn't appear that it's moving. I was hoping to just remove the old and install the new, and was hoping you might have some insight. My only alternative at this point appears to be cutting the "ears" off of the old base, and tapping holes into that and mounting the new US Spars base right on top of that, but I wasn't sure how difficult cutting and tapping the existing stainless base would be.Dave, thanks again for your insight and any assistance that you might be able to provide.T J
