Jim Ory
I've seen the articles previously written about hand cranking the yanmar engines and had the oportunity finally to do it this past weekend when my batteries decided to let me down.I could not start the engine in any way described on the net by the pro's. I pulled the levers and cranked until I could not crank any more. The problem seemed to be that when I pulled the levers and cranked the compression did not change.When the compression stroke came up my cranking came to a screeching halt.After letting the engine set for a while the batteries finally kicked it over and we did not have to sail into the slip after all.Tell me the true secret to cranking this engine so I don't work towards a hernia again......
