Cracks in base of Mast
Patsy
Jul 12, 2010
1
hunter 30 Sausalito
Any 30' Hunter owners (1992) experiencing vertical cracks in base of the mast? Any problems with gooseneck rivets coming out and remaining fasteners loose or damaged?
Hunter 336 Lake Champlain, NY
We own a 1995 Hunter 336 and I noticed one vertical crack (about 3 inches long) at the base of the mast shortly after the purchase. It looked as if it had been there for a very long time and did not seem to get any longer over time. I figured that it might have been caused by some stress due to sail force against the mast.
I did not try to get it fixed or soldered. Instead, I had a SS collar made (about one inch wide) that circles the base of the mast. The collar is held thight by a SS nut and bolt. It simply makes me feel good.
Hope this helps!
Good luck.
