Want to hear from the real "expert" on a technique
Guys, if you're going to jump in before the expert at least read the question! Jan was talking about gelcoat cracks IN THE COCKPIT, so bottom paint is not relevant. And yes, we know it will take some grinding and filling, that's why we're here!I have cockpit and cabin top gelcoat cracks and am considering using a West syringe filled with epoxy to fill them, followed by buffing them down to deck level with a Dremel topped with a fiber buffing pad. I've used the Dremel with fiber pad for taking down epoxy surrounded by gelcoat in the past, and it works without damaging the surrounding gelcoat. I'm puzzling over how to get the same color as the non-skid, which seems to be some kind of Aqua green, so I may mix up samples from the West color set until I find a close match.2 areas I would like to hear from the expert on are: what should I use to clean or prime the cracks before injecting the epoxy, and should I try to cover the epoxy fill with clear gelcoat or will it be okay by itself? Should I expect the cracks to stay sealed (regardless of whether new ones open up)? My survey said my cracks had not penetrated to the wood core.
