CP II vs PH2
A
Andy
Peggy, Is there any difference in West Marine's Raritan CP II and the Raritan PH2 that you recommend? Do you happen to know if either will bolt up where a Jabsco was?
Dec 2, 1997
9,010
- - LIttle Rock
CP (compact) II and PH II two different toilets
The Raritan CP II--and btw, West Marine isn't the only source for it--is a compact "light duty" toilet for small boats and light weekend use. The Raritan PH II is a sturdy "heavy duty" toilet that'll last live-aboards 20 years with minimal maintenance...the PHC is the same pump, but on the CP II base--to fit in tighter space. You can see the specs, dimensions for both toilets on the Raritan website http://www.raritaneng.com/ No...the mounting bolt patterns for either one are not likely to match a Jabsco.
