Covers for sink on a H22
225
Hunter 26 Beaufort SC
My sink boards are gone on my 82 H22. I was going to cut some new ones out of starboard and didn't know if there was already a source for these somewhere. Of if anyone else needs some cut, maybe I should make several sets.
Dec 2, 1999
15,184
I don't think you need Starboard for sink covers. Just cheapo poly board will do the job. You may check on this website for replacements.
Aug 24, 2010
26
Hunter 22 Cape Vincent NY
I cut mine out of 3/4 inch plywood. Since they are also steps into and out of cabin they need to be heavy enough to walk on.
Hunter 29.5 Gloucester, VA
Check Walmart or a kitchen supply or outlet for the solid white poly cutting boards. You can use them a cheap alternative to Starboard in some situations. Also you can check building supply places for stuff called AZEK. It is a white PVC comes in standard lumber widths and lengths and also sheet stock.
