dave
Hello, I have a recently purchased 1981 O'day 28. There were 4 round aluminum instrument housings mounted on the exterior bulkhead just to the right of the companionway. The holes are 4" in diameter. I removed the aluminum housings from the holes. They are fairly heavy-duty and extended about 3" deep into the 2 laygers of bulkhead. There were 4 of them, all sealed in a bit messy with some sort of sealent/caulk that had gotten dry and brittle. Now I have 4 clean holes thru the bulkhead 4 inches in diameter. I have one newer 3" instrument I'd like to install instead of the old empty aluminum cylinders into one of the 4" holes.I'm thinking of cutting andn finishing a nice peak of teak or plywood "cover" about 13 inches x 13 inches which will cover all four holes. I'll put one clean 3" hole into the cover that lines up with one of the existing holes in the bulkhead. Then I'll mount the teak "cover" over the 4 holes and seal it in good with some sort of sealer. I might put 4 screws in it, but don't think it's necessary but might help to get it on tightly. My issues at this point are:1) Was there any structural value to those 4 heavy-duty instrument housings? If I remove them is that bad? They were made by Electro Marines Systems and are really strong, makes me kind of suspicious that maybe they are structural also. They have a heavy-duty lip that protrudes about 5/16" out so I can't put them back otherwise my wood won't be flush to the bulkhead. I could drill or router? 4" diameter countersink holes in the back of the "cover" that would fit over them, perhaps, I guess if there is value to retaining the aluminum housings.2) What kind of plywood or wood should I use? I'll cut it with my saw and have a friend router the outer edge so it's smooth and round. I'll drill the hole. I want to stain it and finish it correctly and have it look nice well as being functional and a proper repair.Any other wisdoms? I didn't want to get into all this but had to move the only newer electronic multi-instrument somewhere. It's a Raytheon Raydata, by the way, and came with the boat. Thank you for any thoughts.dave
