Jon Bastien
Hello all, I'm posting this one as a favor for a friend at the local sailing club... He recently purchased a Cape Dory 25, and has noted that he's having severe corrosion problems with the bronze hardware on board. On his boat, there's bronze a-plenty, so this has him VERY concerned. In a matter of about 6 months, the trim on the ports, the winch hardware, and the thru-hulls(!), cleats, and all of the other miscellaneous fittings have gone from bright, shiny, new-looking equipment to being completely covered in green corrosion. He'd like to know what he can do to prevent this kind of corrosion in the future- Is there anything he can do? He's already chased through all the wiring on his boat looking for stray currents and bad grounds, but found nothing unusual. Will bonding everything together help? Is there any way to attach a zinc to prevent this corrosion (and just how WOULD you attach a zinc to a winch, anyway)? ...Or is this just a matter of needing more frequent application of a little elbow grease and metal polish? It should be noted that our sailing club is in fairly well-protected and shallow waters, with the city marina in the same inlet- the water is VERY hot, electrically speaking. The CD25 has an inboard diesel, and the very large zinc that was placed on the prop shaft last May was almost half gone when he hauled it out last week. Here's hoping some of you 'electrically talented' folks can help us out. Thanks in advance,--Jon BastienH25 'Adagio'(with sympathies for a beautifully maintained but electrically battered CD 25 next door)
