Since the initial drying out of my engine after the installation of the new head gasket, I have not seen a hint of moisture in the crankcase breather trap. Things I said last spring and summer about the water I was seeing demonstrating how much moisture diesel engines generate from blow by on start up were wrong.
The moisture I was seeing was the first indication of seepage from the failing head gasket. I think this alone is sufficient value to have one of these installed (as long as you remove the filter element) aside from diverting oil that will otherwise end up coating the intake manifold and making smoke.
Another thing I have learned recently about my engine is that there is a lot of blow by, as seen by outflow from the oil filler cap when it is removed, at idle. It drops off to almost nothing at cruise speed. The effect may be exaggerated by the extreme installation angle of my engine but I think this shows one of the reasons why prolonged idling for the purpose of charging batteries and refrigeration is hard on engines.
