Peter Hodges
I have a few questions concerning the correct prop for my oday 28 sailboat. The engine is a 11hp universal. Currently I'm using a Martec 14x10 folding prop and can reach about 5 knots at moderate rpm. I don't have rpm meter so I don't know the rpm. I would like to increase cruising speed if possible via changes to the prop. I don't currently race this boat so speed under sail is not a major consideration. I have a recommendation to change to a 12x12 2 blade fixed since this would be more reliable for cruising under power and would provide about the same speed. I've also been told that a fixed prop can be cupped and that this might help.- is 5 knots about the best I can do with this boat and engine?- how would thrust of 12x12 fixed compare with 14x10 folding?- can the 14x10 folding be pitched; what pitch would you recommend?- what about cupping a 12x12; would that make sense?- other thoughts on what's the best prop for my situation?
