Need the correct H260 rudder rake angle
Damaged the head of the rudder where it contacts the vertical SS rudder post. Sailed all last season with a hideous over steer where the rudder, now being raked slightly too far fwd, will take off as helm increases in either direction. I remember seeing a post of a diagram showing how to set the proper rake for a 26/260 rudder but can't find it now.
I've built up and reglassed the contact spot to rake it well aft but now need to determine the exact amount to adjust/grind down to properly balance the rudder angle without allowing it to be raked too far fwd nor aft. Fractions of an inch at the head stop make huge changes in the rake.
My crude drawings below might act as a measuring point if someone could please check their dimensions(assuming they don't experience any under/over steering). Or simply choose the last option for a raw guess and give me the measurement from the hole for the knot in the last pic.
We'll call my needed rake measurement "Dimension C".
Thanks for your help with the correct rake dimension and for tolerating any engineering phases that I've surely butchered.
Mike
Mike
