Coronado 15 Rigging
Feb 8, 2024
4
Coronado C15 CDA
Hey,
I recently purchased a used Coronado 15 sailboat and I am in the process of making some minor repairs.
Does anyone know where I can find / purchase new or used "Spreaders" for the mast rigging?
PaulK
Dec 1, 2009
1,408
Sabre 402 Southport, CT
A rigger might be able to help guide you for this, if the spar manufacturer is not available. Spreaders need to be the right length, but can be made from various materials (aluminum, fiberglass, wood...). Attaching self-made spreaders to the mast can be a hurdle, but people are able to figure it out when they need to.
Feb 8, 2024
4
Coronado C15 CDA
It's looking like I will have to fabricate one. I was thinking about using 1/2 electrical conduit and smashing one end flat so I can screw it to the mast spreader bracket.
Feb 8, 2024
4
Coronado C15 CDA
Feb 8, 2024
4
Coronado C15 CDA
Does anybody have the dimensions or specifications for "Spreaders" on a Coronado 15 sailing mast that I could use to fabricate one? All I need is the dimensions and configuration.
I’ve ordered spar parts from these guys
And when I did the owner called me to make sure I was getting the right parts …very helpful …talked me through the installation as well
PaulK
Dec 1, 2009
1,408
Electrical conduit is usually galvanized steel, so would not be the best material for spreaders. Aluminum tubing would be better.
Plus - look what I found : Coronado 15 Tuning Guide. which says the spreaders should be 19" long.
