Core material??
Feb 16, 2011
1
hunter 386 Georgetown, Md.
Can anyone tell me what the core material is on a Hunter 380? I'm getting moisture readings on an area on the side of the boat.
Jan 12, 2011
930
Hunter 410 full time cruiser
Before doing anything check to see if there is a bulkhead etc on the inside of the boat where you got the moisture reading. My boat doesn't have any core moisture but measured high at every spot that had a liner of bulkhead.
BTW - I'm pretty sure it is balsa coring above the waterline and solid fiberglass below the waterline.
Dec 2, 1999
15,184
Before you do anything, have someone else check the suspected area.
Had a neighbor that had survey. Surveyor said there was moisture in deck. They took core samples and it was totally dry and never was wet.
