Cordless power tools: best for boat?
Apr 11, 2022
76
Irwin 34 Citation San Carlos Meixico
I am going to go buy a cordless hand drill later today or tomorrow. Brands often group them with other power tools and is cheaper to buy the set than the individual tools. I am only 4 months into boat ownership, and not sure which tools are a must have, and which will gather dust (or corrosion). I can't picture needing a circular saw, unless I start a major overhaul and need to work on cabinetry. Reciprocating saws are just fun, but probably hard on fiberglass. Could come in handy demasted half way to Hawaii. Will I regret not getting an impact driver for stuck hardware? I think a jigsaw would be handy, or some sort of dremel equivalent, but I do not remember seeing those in kits.
Thanks for any thoughts. Bonus for input on rivet guns.
Dec 28, 2015
1,923
Impact gun and a drill set. I’m not a fan of Dewalt but the 20volt set I have have been workhorses. The batteries last a long time. The lithiums charge really fast.
Dec 25, 2000
5,950
Hi Dave. Tried cordless drills on the boat, but alas not enough use to obtain any kind of life out of the batteries. Instead, since I have plenty of 12V house bank battery power, I picked up a 12V drill that still had the battery attached from a local thrift store for next to nothing and removed the spent battery guts, then wired in a long cord with a 12V plug on the end. Works great.
Over the years I've installed 12v sockets around the boat; each cabin plus the cockpit. The cord is long enough to reach just about any point where needed. Never have to worry about whether there is available battery power. Just right for those small boat jobs.
Apr 11, 2022
76
I have a friend that did that. He was on my boat helping me drill out a broken rivet. I could not tell if it was his drill, or my power supply, but it was barely able to do the job. I like the idea though, I may just try it on principal. Thanks
Dec 28, 2015
1,923
The newest battery technologies are amazing. I’d take a cordless quality set over a corded (can’t find them in a small size) anyday. You’ll use the impact gun a lot and have the drill for emergencies.
76
The newest battery technologies are amazing. I’d take a cordless quality set or we a corded (can’t find them in a small size) anyday. You’ll use the impact gun a lot and have the drill for emergencies.
I can see the impact being pretty useful, thanks for confirming.
capta
Jun 4, 2009
5,006
I always used cordless whenever possible, even with a genset. However, it was always a pain to recharge the batteries as we normally only ran the genset for 1/2 an hour twice a day. Then I found a Ryobi charger that ran off 12 volts and using that and their +1 batteries I never had another problem with half charged batteries for my cordless tools.
The tools I use the most are a cordless drill, an impact drill, oscillating tool, and a sabre saw. An angle grinder is also handy.
Since the tools will live on the boat, don't over buy, midrange tools work well. On the boat we have Porter-Cable. Lithium batteries are best because they don't self discharge, recharge quickly and are smaller.
Jan 4, 2006
7,431
I have an old hair dryer permanently on board for working on hoses. Won't start a hose job ( :)) without the dryer handy.
When it comes to electrical wiring, a heat gun is a must for glued electrical heat shrink tubing.
Jan 7, 2011
5,858
Oday 322 East Chicago, IN
Impact driver, drill, oscillating tool, jig saw, angle grinder. If you could also get a small circular saw in the package, that would be icing on the cak.
i like Master Force sold at Menards (good value brand). But if traveling the world, better to go with a big brand like Ryobi, Dewalt, etc.
Greg
Likes: patagoniadave
Apr 11, 2022
76
Greg
I forgot all about oscillating tools, thanks for the reminder. I'm m in Mexico, so it will be interesting to see the brands at home Depot
Jun 2, 2004
3,606
I have Dewalt, not for any particular reason except started out with those as it was on sale. One advantage is they are sold everywhere other brands seem to be sold at one store and not another. The oscillating saw you will use more than you think. I've bought other tools that go with the battery line that have proved their worth many times over. The fan has been a life saver on several occasions. The usb adapter for the battery has been a godsend to charge a cell phone when other options were not available. Cordless grease gun seemed silly till you've used it. Flood light and spotlight e worth having well. 1/2" and 3/8" impact get used a lot. They have just come out with a 20V 3/8 ratchet, that'll be on my Christmas list.
They have a line of 12v tools as well that would probably be fine for most tasks on the boat but unless they are way cheaper than the 20v may not be the value they seem to be.
MFD
Jun 23, 2016
249
Hunter 41DS Pacific NW USA
Over the past ~5 years I have trended almost entirely DeWalt. The thing with cordless equipment is that often you are buying into the battery/charging system for the tools so mix & match does not work well. I keep one of the higher powered chargers on the boat and have two batteries - one thin, one heavier. I also have some other heavier duty corded equipment that I usually do not keep on the boat but is also rarely needed. DeWalt also has a little mini shop-vac that does double duty for basic boat cleaning on a regular basis. In all honesty the mini-shopvac thing is not that great, but having the same batteries/charger for everything makes it a win for me.
+1 on picking up an oscillating saw even though you may not be exactly sure right now what you are going to use it for. Extremely handy tool for cramped spaces, oddball cuts of weird materials, etc.
Apr 11, 2022
76
I had an oscillating saw in the RV (used it all the time), but it was corded, so my brain was not making the cordless battery powered connection (lost all those tools in the divorce). I did love all the random extra things like a light or phone charger than ran off of the battery system. I think the one I had was Ryobi or some such brand.
Thanks for the feedback, it is very much appreciated.
MFD
Jun 23, 2016
249
Yeah - it seems kind of silly, but the little LED lights that most of the modern tools have are super handy!
Jun 2, 2004
3,606
Dewalt makes all sorts of lawn equipment as well I have the blower, line trimmer and chain saw. If my mower ever goes out I'll have one of those as well.
I am waiting for the Dewalt outboard motor. They are missing the boat on that one.
Apr 11, 2022
76
Chainsaw might do better than the "sawszall" in a de-masting situation....
Nov 21, 2012
795
Momentarily Boatless Port Ludlow, WA
I'm a fan of the Milwaukee M12 series of tools. Smaller and lighter than my DeWalts, plenty of torque and battery life.
