I have a westerbeke 10-2, diesel inboard. It is cooled with both fresh water and sea water.
the intake for sea water (thru hull) has a sea cock that can be shut off and another valve above it in the boat with a hose attached that should suck water . when I ran motor with the hose in bucket it did was not pumping water out of the exhaust. Last year while in the water it worked fine with the thru hull suction?
I closed the thru hull valve and opened the one with the hose attached.
did not want to run it for long with no water running out of the back.
can anyone offer any suggestions or help?
Thanks
Thanks
