Cooling problem
Apr 20, 2002
5
Occasionally and without any clear reason the temperature alarm of
my MD6B is sounding. I checked the sensor in hot water and it
switches between 65 and 70 degrees celsius. The impellor is ok and
water is rushing through at a normal rate. At the side of the sensor
it shows 75 degrees as operating temperature. Do I have a sensor
problem or a clotted cooling system? Or another problem?
It's outboard cooling.
Any suggestion/idea/solution is welcome.
V1737, Ries den Besten
Nov 8, 2001
1,818
Hi Ries
The usual reason for the overheating is the exchange manifold being partially blocked. Take the manifold off and clean at home. Can take a bit of time but will really bring the temperature down. Had this problem on more than a few Vegas with MD6A and MD6B and MD7A engines. You will need some rods and patience.
kind RegardsSteve Birch Vega "Southern Comfort "V1703
