I have used the Yanmar brand antifreeze since new. Change it every other year. Premixed. My 4JH4E takes roughly 1.5 gal.Is there a specific type of engine coolant you should use for the Yanmar engine? I've owned several John Deere tractors (Big ones) that do require a specific coolant.
I wanted to make sure that I was adding the correct coolant. I'm pretty sure it's the small little plastic type bottle to the upper left corner of the engine where the coolant is added and held. I don't recall seeing a marker for the level anyone know how much to fill?
And. Engine oil what type are you using?
Hunter gaskets for all!And now a word from the sponsor...
