This is a Universal 25XPB engine. Had a problem with the overflow tank not working properly. The coolant would not go back into the reservoir. I finally lost all of the coolant from a leak I am still searching for. The coolant in the overflow tank still was not going into the reservoir. I took the elbow off of the reservoir and found it to be completely clogged, also the hole which it threads into was clogged. I cleaned out the elbow and tried to clean out the hole in the reservoir it threads into. I finally decided to drill into the hole to clean it out. I was starting to get metal shavings when I was drilling and stopped. Does anyone know if that hole goes all the way through or if there is a channel below the hole which lets the coolant into the overflow tank? I don't want to drill a hole where it doesn't belong.
Thanks,
Mark
Thanks,
Mark
