I am planning to flush my Perkins M50 with Rydlyme using the bucket and 12 volt pump method and a few questions have popped up in my head:
- Rydlyme concentration - straight from the bottle or cut with water?
- Procedure - I'm planning on taking one of the water heater hoses off the engine and attaching it to the pump and then putting a temporary hose from the barb on the engine where the hose was removed into the bucket. This should create a loop and the thermostat will be removed. My concern is the engine water (coolant) pump - how do the Rydlyme and subsequent water flushes get into and around the pump and circulated all through the engine and cooling system with the pump's impeller in the way and not running?
- Coolants - there seem to be a dizzying array of options currently on the market. Color alone doesn't necessarily seem to mean anything anymore and there are also low-toxicity products available. Other than avoiding dex-cool, any specific recommendations on products? This engine has an aluminum block.
