The long and short of it.
Prior owner says that the 'Closed-Loop' fresh water cooling system should be drained and refilled every second year. (In the 'olden days' I did that wiyh all of my cars ... no longer seems necessary. He gives this description of draining proceedure:a) With the engine at operating temp, but NOT too hot, slowly remove the cap on the expansion tank.b) remove the pressure cap.c)Loosen 3 drain plugs of the (1)engine, (2)air cooler, (3)heat exchanger. Need a small jar and a 1 gallon jug for the waste.d) use a 50/50 mixture of automobile anti=freeze and water to refill 1/2 gallon each. Quick answer is 1 gallon.The YANMAR manual says that the cooling water capacity is 2.9 L. I personally don't belive that is equal 1 gallon, based on the flush capacity of a modern urinal ie, "1G/3.8L".Have fun ... "It's all part of the adventure"
