Coolant Analysis
Tim
When I put my boat up for winter storage this year I had the yard decommission the engine etc. Part of this was to do a coolant analysis. Now,, I had them do this last winter and they recommended changing the coolant because it could not protect to a cold enough temperature up here in Maine so they did. Now this year they are saying the coolant can protect down to -45; but also that there are abnormal solids present. There is a burnt odor, excessive foam and no oil. My questions is how can this be? The engine is a nearly new Universal diesel in use just 2 seasons. I never got a high temp alarm and always (honestly) checked to make sure water was coming out in the exhaust. Between their last change and this sample the engine was used at most 15 hours. Is this a sign of a problem, is this normal, can this be right? Someone enlighten me, please.
Aug 26, 2005
49
ERICSON 34 Mattapoisett
Needs a Flush
Hi Tim, The contaminant is in the cooling system and if the cooling system wasn't flushed when the new engine was installed, the old contaminant is still there. ITry draining the cooling system and then a good flush. See what comes out the exhaust. Maybe a power flush. -45 protection is not unusual. Where I used to live, -45 was de riguer for cars.
