Propane to CNG
I agree that you should find a source before considering a conversion. I believe that most major stove manufacturers have orifice kits to convert a stove to CNG from propane. The CNG tank looks a lot like an SCUBA tank and is heavier than a Propane tank. I don't know whether or not existing hose can be used. Here in the SF Bay area, Svendsen's Marine is the only supplier I know of. Svendsen's pumps CNG from the city gas lines right into the CNG tank. Natural gas powered low emission vehicles also use CNG. I have not researched whether these refill sites can fill the Safegas CNG cylinder. We live aboard and a cylinder lasts about 6 - 8 weeks and costs $15.40 for a refill. BTU/lb is 21,300 for CNG and 19,800 for propane - in other words, more heat per pound for CNG. CNG is not the choice if you are considering cruising as it is not readily available in other counties.Rodney KiddC-38 #297, Flying Bear
