Converting head in Catalina 27
14
Catalina 27 Noank, CT
Does anyone know of any good links or books that describe how to convert the existing head to an interior tank?
Jun 9, 2004
14
Thanks Peggy
Peggy: After a lot of analysis, we determined that the best solution is to rip out the old, illegal head, and cap the pipes. We went with a 5 gallon porto-potty and installed it to the same location as where the original head was. Think of it this way: The cost of coversion isn't worth the aggravation, between buying a new tank, buying fittings, and drilling holes in the old fiberglass, plus having a large bill just wasn't worth it -- and you don't get the smells. The bottom line is that we decided to keep it simple.
Dec 2, 1997
9,011
- - LIttle Rock
I hope you opted for permanently installed version
fitted for pumpout...'cuz a full 5 gallon tank weighs about 45 lbs, which is a LOT to carry off the boat and up the dock to somewhere you can dump it. A vent line & thru-hull and a pumpout line & deck fitting aren't that much to install, and make your life much simpler. However, it does require a portapotty that has the fittings installed in the tank to connect to a vent and pumpout.
