Yes!!! Nobody in his right
mind would bring high pressure gas to an appliance.In an earlier post I said to go to an appliance store and talk to the parts man, he'll fix you right up. Of course you have to change the regulator, among other things the tank connections are different. But the jets are all standardized and a parts man can supply the right size jets for converting from natural gas to LPG or back. Most kitchen stoves are sold with two sets of jets for Natural gas and Propane and the installer matches the jets to the fuel. The pipes that bring the fuel to the stove from the source don't care what kind of gas you use. Propane contains more heat per unit volume than natural gas so the orifice is smaller in a LPG burner than in a Natural Gas burner.
