H31_83-87 Refrigeration
Doug, I purchased the Model 40.12V 3Amps max pull when getting down to temp and 1Amt to maintain (per specs!)I choose this unit because I wanted 12V and it would run with a high ambient temp (I think it was spec at 110Deg) that way the I could mount the Condensor in the starboard laz and not have to add any ventilation, no heat build up, no added exhaust fans. No through hulls cut! Briefly how I installed it.Mounted the Evaporator on the port side of the ice box as far astern as possible (about 2 inches off the back wall) and as high as possible (about 2 inches down from the top). Unit is only 12 X 12 inches. I cut the hole for the tube from the back of the box and it came out just above the Evaporator connection. Yes was a tight fit to get it hooked up and check for leaks, but it is up, out of the way and not easily disturbed by contents of the box nor touched by hands.Mounted the condensor on the BACK of the box (starboard laz) at an angle so the CO2 would run down to the Evaporator (per specs). VERY short tubing run to the Evaporator (which is good). For good power had to make a run direct to the battery with a fuse.Adding CO2 was a bit tricky. Took a couple of trys to get it right, plus I had leaks the first time because I used Lowe's 1/4 " copper tube connections. Company made a small modification for my install which eliminated all splices.Service? THE BEST! Tom the salesman and Ernie the engineer know the product and had the answer or solution for any problem! Maybe I should not tell this one, but since I could only work on my install on Sundays, Tom answered my every call and that is how he determined the modifications to make my install better.Well worth the money! Unit has been running almost continously for the past year. I check the Amps when I first installed it, yes 3 Amps to get box down to temp and 1 Amp to maintain. NO, I did not add any additional insulation to the box.If you are serious, I will be glad to provide additional install tips via telephone or e-mail, I am listed in the owner's directory.Did you order the pedestal table?bill
