Ah, I see the question. Dr. H. has another post, but this one is regarding moving to a salt water environment from fresh water.
Dr. H.: we have a situation where we are berthed in fresh water and travel back and forth to a salt water environment. There is nothing different other than the fact that you should have the bottom cleaned every 6-8 weeks (depending on the conditions) and need to keep an eye on the Zinc's so you do not have corrosion issues with the prop, shaft & strut.
