Do you have any problems when furling the sail because of the battens? Do they need to be perfectly parallel to the mast?Hi Skywalker, I have a 361 also and have replaced my main sail with a new Neil Pryde Main Sail with Vertical Batten and it made a difference. I can know point higher and the sail has a much better shape. By the way, on my Charleston Spar Mast there is an extra slot to raise another sail when the main sail is rolled in. I assume it is to raise a storm sail but I don't know how to do it because there is no extra halyard.
Georges
Hi Philip, No I have no problem furling the sail with the battens. When I first got the sails the batten were too large and I had problem with the velcro on the batten pockets. The batten were replaced by Neil Pryde and since no problem at all. We I bought the O361 I inserted a track on top of the boom and a Lewmar Ball bearing outhaul car, at the suggestion of David Levy from CharlestonSpar, and it works like a charm.Do you have any problems when furling the sail because of the battens? Do they need to be perfectly parallel to the mast?
I don't have Profurl but Facnor.I think I have too much mast rake. The genoa Profurl is installed at the lowest of the three holes in the bottom bracket, could you tell me please were is yours. I thought that maybe it should be installed using the middle hole, which would shorten the staysail lenght. Thanks.
Regards, Georges
