Have One
It was a factory option. I have an inner forestay on a quick connect. I also have a jib for the unit. After six years, I have never used it, but would if cruising longer passages than a couple of days. Of course, with the stay mounted, tacking is a pain. If you have a good reason to do it, check with Hunter regarding the location of the mount, etc. (It is in the aft section of the anchor locker.) They may be able to build the chainplate to the factory specs. Rick D.
