I have a Hunter 260 with a pedestal, the shifter cable for the outboard engine has broken. Does anyone have experience in changing them out and how difficult is it ?
Thanks
Jnc
You need 3300 series cables 11 feet long. It can be tricky about the part thru the pedestal. Take off all the ends on both sides and insert into a small tube toward the hole at the base most forward port side and then reach underneath with a crowbar or something to hook underneath in the gas locker and pull. The other is hard but you will figure it out.
Thanks Dave,
You may be familiar with this boat. You brokered it, we purchased Simplicity in Nov. 2007 thru your previous business. We have enjoyed sailing her. Hope all is well.
Jnc
S/V Simplicity
Anytime sir. Email is davecondon@mindspring.com and reference the Hunter 26. I am still supporting my customers via knowledge to them.
I was a bad boy and went behind the fence and touched the Shuttle Discovery. It was a great feeling. I grew up around the original astronauts and will remember when Gus Grissom put his arm around me the night I learned my father was killed and said I was his third son.
