The contra weight that lowers en rises the salon table has fallen down the mast foot. It looks like it's stuck now. How can i losen this weight and use it again to easen the rise and lift of my table?
Hi Frank, is the cord that connected the counter...
weight to the table still accessible? If so, perhaps squirting some Liquid Wrench down the compression post will loosen the weight? Also, while someone pulls on the cord tap on the post around where the weight rests might work it loose.
Worst case would be to remove the compression post to gain access to the counter weight. If I think of more options I'll let you know.
The cord is still on so I can try this manner. At first I tryed it with liqued wrench. That didn't do anything.
I assume that a rubber hammer is the bst way to losen it while someone is pulling the cord.
To remove the compression post looks a no go to me because my mast has to come of first I would think.
I try the hammer method and let you know if it did the job. At first I have to ask my brother to assist.
Hi Frank, you are welcome. I'd like to hear back...
as to whether these tips worked. Also, I would contact Hunter Marine Customer Service and ask them how to remove the compression post without dropping the mast, if it gets to that point. I would think you could place a temporary support post jacked into place to support the mast and coach roof while the compression post is removed.
I think that is also a possibility. Maybe the water (if there is water) causes a vacuum. It's worth to investigate! Maybe with use of the rubber hammer to losen the weight.
