Continuing my Oday 192 survey... bear with me!
Mar 20, 2020
69
Oday 192 Eagle Creek Reservoir
Hi all! Thanks for the comments on my last posts. Wondering if you might be able to help again as I try and sort the electrical for my Oday 192. I currently have the circuit breaker, the voltage meter, cigarette lighter (as you can tell I'm not an electrician by any means), and a rats nest of old wiring.
No cabin light, no fan, no battery. I do have an anchor light, bow light, and transom light. I would love to have some type of diagram to help me get things in the right place. Anyone have something like this?
May 24, 2004
7,164
CC 30 South Florida
There are plenty of books on Boats wiring out there and I would recommend "Sailboat Electrics Simplified" by Don Casey.
Mar 2, 2019
570
Oday 25 Milwaukee
As someone who bought a boat that was wired with lamp cord and masking tape ,perhaps my experiance will help .
I was able to find a schematic for my boat when it was new . So much had happened by subsequent owners that none of the original
wires actually did their original job .
I ended up pulling as much of the orignal wiring as I could and started from scratch .
Some of the factory wiring ran between the ceiling and the deck itself ..
It might sound like a lot more work up front.
I did this for two reasons . The first being I knew exactly which wires did what and that they were correct .
All circuits were drawn out ahead of time and fused correctly .
Second ,our boat was made in 1981 . Since then we sailors have added a great deal more electronics . I wanted to leave room for charging circuits , dual batteries , solar panels ,auto pilots and chartplotters. Most of these are almost considered mandatory ,by some .
I also chose to switch to LEDs lights in an effort to reduce the amps used .
I hope this helps
Mar 20, 2020
69
I hope this helps
Yes this helps! It’s exactly my plan, actually. The wiring looked so bad I didn’t really trust any of it. I plan to give this thing a fresh start when it comes to electronics. Where did you locate the schematic? I haven’t had luck doing so for my boat yet…
  • Sad
Likes: Timm R Oday25
Mar 2, 2019
570
Oday 25 Milwaukee
I'm pretty sure it was here on this forum ,under boat info . The drawing was done by hand and not very encouraging :huh:
Idon't believe the 192 was sold with electronics. That would be an owner installed option. The Mariner was the same. Today, I think the Mariners produced by Stuart Marine may be available with electronics, but I am not aware of the 192 having that option from the manufacturer.
-Will
