Hi,
A few months ago there was some discussion about a hidden void in the
keel, below the bilge area.
I found out about this void when I noticed some moisture in the aft
part of the keel. I drilled a small hole there and noticed the keel
was filled with polyurethane foam, which was now completely saturated
with water.
Now I have made three large holes in the area and removed all of the
wet foam. And there was lots of it, this void is huge!
But I am hesitating what to do next. Should I fill the void again,
hoping that modern closed-cell urethane foams are better than their
60's counterparts? Or should I try some other compound? Or simply
leave the void empty - and install a small drain plug in case some
water gets there again. I wonder if leaving the void empty would
weaken the keel structure?
I made a picture of the construction of my keel and uploaded it to the
files section. My hull is #68 from 1967, I suppose all early Vegas
have a similar construction.
As you can see in the picture, the void in question is really large.
I'm not sure how water got there in the first place, I suppose it came
through the bilge. The plywood planks supporting the bottom of the
bilge were also wet, but not yet rotten.
In my opinion this is a serious issue in all Vegas with this kind of
construction. Water in the void may cause freezing damage and
eventually delamination of the keel. Plus the saturated foam will
loose any structural signifigance, it it ever had any. Has someone
else opened their keel to see what is inside? I wonder if they are all
filled with this stupid foam.
A really bad design by the manufacturer, in my opinion. Inside the
void I also found two iron nails, a few copper nuts and some really
sloppy laminating work. Half expected to find some cigarette butts
too! I'm no more convinced of the excellent build quality these boats
are said to have...
Nuutti
with water.
are said to have...
Nuutti
