Considering ElectroScan... a few questions
Since my holding tank appears to have a small leak and will likely need to be replaced, I've been giving strong consideration to replacing it with an ElectroScan w/Hold n Treat controller, and a much smaller tank (for when we're in a harbor).
The main installation obstacle I see is that although my water intake line has a vented loop, the 1" line that currently goes from the macerator output to the thru-hull does not, and looking through the manual it appears that this is a requirement... could be tricky getting that hose up to the location where the vented loop could be installed.
My other question is in regards to something mentioned in the manual. It says if the device is to not be used for more than a few weeks, it should be flushed with freshwater to purge remaining saltwater and waste from the chambers (and then before using again, saltwater should be pumped in to displace the freshwater).
With the system all plumbed together, how does one go about pumping freshwater through it?
--Michael
--Michael
