C
Claude L.-Auger
Just got back home from my Hunter 34. Got splashed Friday and mast was stepped same day. Yesterday was too nasty for it, but today I spent 1 1/2 hour in the bosun chair, to try and understand why my radar (JRC 1500) did not work. I had to re-install it last week and it had tested OK at the shop. Power does reach the unit, but breaker trips if I keep the ON button depressed longer than would normally turn the unit on. It is not a faulty negative ground as the breaker would trip immediately. Amps tests at 3 amps (unit rated at 5). Everything looked good with the connectors inside the radome, so I am suspecting a connector got crushed at the base of the mast when stepping it. Which means that I now have to go back to the crane, unstep again and find the culprit. I am getting real tired of playing this game and would like to cut a small window about 2 inches from the bottom of the mast, which is deck stepped. I have searched the archives to see if anybody has done it. No luck in finding anything.Questions: would it affect the structural integrity of the aluminum mast if I cut a small window about 2" wide X 3 1/2" high. Of course the corners would have a radius. It would be covered with a SS plate which would be held by small self tapping screws.It would really be a tremendous help to me as I have to step and unstep the mast 3 times each season when I travel out on vacation.Any help would be appreciated.
