Hi all,
I am working on a custom 24:1 backstay adjuster.
The important constraint is that I want to use the two existing D-rings on the boat and NOT add another one.
I will be using the attached design (see attached figure).
I will need to connect two pieces in the port D-ring
(one is the triple block and the other is the end of one of the lines).
I am concerned about chafing issues.
The question is the following:
Is there a piece of hardware that can "separate" the two attachments?
I am thinking of a triangle-like piece that has three holes: one connects to the D-ring (through a shackle)
and the other two lines are connected each to a different hole so that they stay apart from each other.
If there is such a hardware I would consider buying it instead of custom making it from steel...
thanks in advance,
Achilles
thanks in advance,
Achilles
