In order to eliminate smell in the toilet after no use for extended periods in the salt water environment, I understand the solution is to fill the Head Pickup line with fresh water. Other posts have used the Vanity Water Basin. I want to install a T in the Head Pickup line next to the thru-hull and another T adjacent to it in the Vanity Drain Discharge next to the thru-hull, and join the two T's with a valve gate. I'm hesitant to disassemble the factory lines until I am certain what parts to use. Has anyone ever tried this? The outside diameter of the Vanity Drain line (coiled) is 1.5 inches, while the outside diameter of the solid white Head Pickup line is 1 inch.
If I can make the installation successfully, then filling the Head Pickup line with fresh water will be easy ... close the hull-thru gate valves for each, then pour fresh water in to the Vanity sink, and then operate the toilet on "flush" in order to suck fresh water from the sink down thru the new valve and over to the Head Pickup line and up to the head.
Any thoughts?
Any thoughts?
