I hope someone can straighten me out on this issue. I have a Hunter 36 with 2 new 4D batteries with parallel connection. I have a battery charger/inverter with a toggle swiitch 1-BOTH-2-OFF. Under this area, I have 2 on/off switches for HOUSE BATTERY 1 and HOUSE BATTERY 2. i'm told when mooring out to switch to HOUSE BATTERY 2 to run the AC powered devices and to save BATTERY 1 to start the engine. The problem is that when I switch back to BATTERY 1 and check the voltage readings both batterues are the same, always. I've shut down everything on the DC panel and have run microwaves, hairdryers, etc trying to get a lower reading from BATTERY 2 and it doesn't work. I've been told that parallel connections, while increasing capacity, charge and discharge equally. If this is true, is the inverter wired to the battery. Do I need to wire each battery separately to the respective switch to be able to go from one battery to another and if I do this, am I going to lose the extra capacity of the 2 parallel batteries. Any thoughts and advice would be really appreciated. thank you
