Inner Forestay
Just a bit more information Gary. Where up on the mast is this inner stay attached? Is it up just below the regular forstay attachment at the top of the mast? Or is it lower on the mast, say 3/4 way up? If it is attached up at the top of the mast it is callde a Solent stay and could be a handy additional way of bringing the force from the wind closer to the centre of effort of the boat, reducing weatherhelm and heel of the boat. If you are doing lots of bashing to windward in heavier winds it can be a beneficial sail plan if it is mated to a heavy weather sail (smaller and thicker sailcloth). But if it is attached much lower on the mast and there is no additional backstays (running backstays) to oppose this imbalance in forward pull (forestay plus baby stay) then you are jeopardizing the mast at this unsupported portion of the mast where the inner stay is attached, and risking collapsing the mast. Moving the upper stay attachment of the inner forestay to the forestay attachment at the top of the mast solves this problem.In addition how is the lower attachment point, at the deck, supported below deck? I have the exact same boat and can't think where you would anchor a padeye to? It should be attached to a bulkhead just as your side stays are using a chainplate or an beam that spreads the loads across the underside of the deck. Perhaps it's attached at an anchor well bulkhead? At the very least it should have a substantial backing plate spread over the underside of the deck as the pressures on this padeye could be substantial, especially in a blow.How is it removeable at the deck padeye? As the other guys pointed out it should be easily removeable and brought back to the mast when not needed. The addition of this extra stay can be a benefit, if it has been set up right.Don
