I
IslandJack
I am hooking up a vhf. Since the mast was raised by me after being refit with a new coax and antenna, I thought I would check the lead before I hooked to the radio. Testing with a multimeter, I get infinite resistance from the conductor to the shield. I was expecting some lesser resistance to wag my meter. Anyone know offhand if the vhf antenna (Raytheon) on a boat is generally a 'no ground plate' or 'ground plate' installation.I hate to climb the mast to find out all is well and the no continuity measurement is normal....and I hate worse to kill a radio by xmiting up a dead end.Along those same lines, I have a little cb i was going to install....it's antenna is ground plate and reads resistance from coax to conductor. What are you guys using for a CB antenna?IslandJack
